1 members (Hotrod Lincoln),
61
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96529 08/01/2006 6:49 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | I have a cab light but nothing works. I looked for door switch and found nothing. I thought turning the headlight switch would do something but I get nothing. How does this work? Where is the switch supposed to be? O Blue 65 stepside I love to duck hunt. [email protected] | | |
#96530 08/01/2006 7:20 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no door switches on these most basic of vehicles - turning the headlight sw alla way one direction turns the interior lite on, other way dims the dash lites - have you checked the bulb?  could be bad wiring too, or even that part of the switch bad - works by putting a ground on one wire to the light, the other wire to the light is always hot from a terminal on the switch Bill | | |
#96531 08/01/2006 6:39 PM | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | You can add door jamb switches for the dome light if you want. You can also add a 'delay' so that the dome light stays on for x seconds after you close the door. LMC advertises the delay and the jamb switches are pretty standard stuff that are easy to wire up.
#96532 08/02/2006 2:35 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Yes I did changed the bulb and I did suspect the headlight switch, after all what else is there. The switch does feel/operated poorly so I guess I will change it along with everything else I am changing.
steve O BLUE A Louisiana truck..... Hurricanes are a big pain in the ***. | | |
#96533 08/10/2006 4:27 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | I pulled the switch, hit it with some electrical cleaner and then some WD 40. It feel great and works great. O BLUE Looks good runs great. I smoked 20 duck breast tonight and sampled about 4 with a wonderful bottle of red wine. Write me for the receipe, it will knock your socks off. [email protected] | | |
