3 members (Otto Skorzeny, MNSmith, tclederman), 73 guests, and 1 robot.
Topics128,052
Posts1,055,718
#96529 08/01/2006 6:49 AM
Junior Member
Junior Member
I have a cab light but nothing works. I looked for door switch and found nothing. I thought turning the headlight switch would do something but I get nothing.
How does this work?
Where is the switch supposed to be?
O Blue 65 stepside
I love to duck hunt.
[email protected]
#96530 08/01/2006 7:20 AM
no door switches on these most basic of vehicles - turning the headlight sw alla way one direction turns the interior lite on, other way dims the dash lites - have you checked the bulb? grin could be bad wiring too, or even that part of the switch bad - works by putting a ground on one wire to the light, the other wire to the light is always hot from a terminal on the switch
#96531 08/01/2006 6:39 PM
You can add door jamb switches for the dome light if you want. You can also add a 'delay' so that the dome light stays on for x seconds after you close the door. LMC advertises the delay and the jamb switches are pretty standard stuff that are easy to wire up.
#96532 08/02/2006 2:35 AM
Junior Member
Junior Member
Yes I did changed the bulb and I did suspect the headlight switch, after all what else is there.
The switch does feel/operated poorly so I guess I will change it along with everything else I am changing.
steve
O BLUE
A Louisiana truck..... Hurricanes are a big pain in the ***.
#96533 08/10/2006 4:27 AM
Junior Member
Junior Member
I pulled the switch, hit it with some electrical cleaner and then some WD 40. It feel great and works great.
O BLUE
Looks good runs great.
I smoked 20 duck breast tonight and sampled about 4 with a wonderful bottle of red wine.
Write me for the receipe, it will knock your socks off.
[email protected]
