1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96521 08/01/2006 6:46 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | My new 65 has nothing at all in way of backup lights. I can buy replacement lights ok but have no clue as to how they worked in past. Did they actually work when you put it in reverse? HA. Is it worth pursuing? I was going to rig a manual switch to turn them on when I need them.
Vehicle inspection in Louisiana is strict. No sticker and you get nothing like plates, insurance etc. I simply told the guy they didn't have backup lights back then and he thought that was cool and gave me a sticker. I'm rolling!
O BLUE 65 stepside | | |
#96522 08/01/2006 8:23 AM | Joined: Feb 2000 Posts: 268 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 268 | Back Up lights were not required tell 1966, so all 1966 & newer should have them, 1965 & older only got them as an option.
Your best bet is to just hook them up with a dash mounted switch.
Here in Utah the only requirement on back up lights is that they are not on when going forward, if they don't work in reverse, no big deal. | | |
#96523 08/01/2006 10:45 PM | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Check out E-bay and the swap meets. You may get lucky and find an original dealer backup light kit. These included all the parts to install them, the lamps. switch, and harness. They should inculd both the column and floor shift parts for the switch. I found one for the '55, still in the original box. It wasn't cheap, $250, but I think that it was worth the cost to have lighting when i back up. The only change i made was putting halogen bulbs in for more brightness.
Bill Burmeister | | |
#96524 08/02/2006 2:42 AM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Thanks Jolly your reading my mind. Longbox, I am inclinded to do the original thing but my column is giving me all sort sort of trouble right now with shifting (another post answered today) that I think I want to stay away from it. I did not know they were an option. I have the holes in the back where they were mounted but I found no wires or anything at all that indicated they ever were there. So I think I will go the way of the switch. | | |
#96525 08/02/2006 3:47 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | shor,
Didn't most transmissions come with a switch installed in the tranny to address the backup lights. I don't know if this would be the case with yours, but if so, it certainly would be more convenient than having to manually switch every time you wanted to back up.
The switch usually had two poles, and was NO (normally open). When the transmission was shifted into reverse, a ball, or plunger was depressed closing the switch and completing the circuit. They are sometimes hard to spot..covered with gunk and hidden. It might be worth the search.
Stuart | | |
#96526 08/02/2006 5:03 PM | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | To answer your question atomarc, no, not until the SM465 4 speed did one come with a internal switch. The 3 speeds were mounted to the shift levers on the column. Installed plenty of these at the various full service gas stations where I worked after school and early in my military service. Shor; if you go the switch route mount a idiot light next to it to remind you to turn it off, that way the local cop don't have to.
You Learn more Listening than Talking
#96527 08/02/2006 6:53 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Spareparts2 Thanks for the info. Sure miss those full service gas stations. Stuart | | |
#96528 08/02/2006 9:03 PM | Joined: Jul 2006 Posts: 34 Junior Member | | Junior Member Joined: Jul 2006 Posts: 34 | Ok thanks Spareparts2. I will go that route.
steve shor O BLUE 65 stepside | | |
