1 members (Hotrod Lincoln),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96498 07/26/2006 5:50 AM | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | I'm either blind or stupid or BOTH....
My 46 Chevy didn't come with a horn when I bought it. I want to install a stock horn and stock horn mechanism. I understand how the horn button operates (provides the ground leg to complete the circuit), but I can't find the exit location of the wire itself. Does it travel down the steering column for a while or what? I can't find that wire anywhere, maybe it's missing????
Thanks in advance.
46Possum | | |
#96499 07/26/2006 2:50 PM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My 38 runs down the inside of the steering column & exits above the stering box on the engine side of the column. I don't know if that applies on a 46 but it's worth a look.
#96500 07/27/2006 2:23 AM | Joined: Jun 2006 Posts: 35 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 35 | Thanks Tiny...
I looked (well, felt with my fingers) and found a hole on the bottom side of the column a few inches above the steering box. No wire, though. I'm thinking this must be the exit point, maybe someone else can verify that.
Thanks again
Rich 46possum | | |
#96501 07/27/2006 2:37 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Yup.. that’s it, about 5/16” in diameter when the grease is removed. To run the wire I removed the steering wheel and un-clamped the column both at the bottom and below the dash. Then I slipped the column up the shaft until it hit the inside of the cab roof. After removing the old top bearing and cleaning the grease out of the bottom of the column I dropped a length of fishing line with a small weight down between the shaft and the column. Then I fished the line out through the correct hole and then pulled the wire through. If you need photos of the horn assembly I can pass along the ones that one of the guys here sent to me | | |
#96502 07/27/2006 2:38 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Your assumption is correct, that's the exit point. The wire will be connected to the back of your mast jacket bushing & should be fed down the steering column. I don't believe the hole is large enough for the connector so you'll probably have to solder it on after pulling the wire tip through the hole.
Oops, Kip & I posted at the same time. If the hole is that large the connector might just fit through it. It looks like Kip has done this before and will be able to give you first hand info.
