3 members (Gdads51, gswbbc, Hotrod Lincoln), 142 guests, and 2 robots.
Topics128,047
Posts1,055,532
Members48,424
#964959 08/19/2013 1:40 AM
If there is a casting number of 839910 and a 41 pink slip with same number how does this happen? most casting number sites say 839910 is 42-53 year ???
Could it be a late 41 truck with 42 motor?
Yes, just about year 216/235/261 engine could have been swapped around.
Also, your 1941 truck might have come with a 1942 motor.
Or, you might have a 1942 truck that was sold as a 1941 truck.
What is a "pink slip"?
839910 was a 216 block casting code from 1942-1947
Find and post the head and block date casting codes.
What code is on your Vehicle Serial Number plate? (if you can find a plate)
That's what I'm thinking new model (42) sold in late 41
pink slip is title
