0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Tank still behind the seat? Maybe make a new shift lever. Even when my tank was behind the seat I never had that issue. Always had b&m mega shifter. Then again I have a stock seat.
| | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | can someone please explain this to me I was reading on the B&M website and it said since I have is cable operated shifter the one that looks like a 4spd one it will fit a bench seat. what I want to know is how does work.how can I make my shifter so sorry for my bench seat so I'm able to go down to low gear | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Move the assembly forward. When mine is in park I'm close to punching the bottom of the dash. Mine looks was different than the boot you have. Was your truck a stick before? B&m sits on a big bracket. All I see is shifter lever on your photos.
| | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | it was originally a three speed? | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | You'll have to buy a b&m or comparable I think. It raises the whole assembly. It raised the whole thing about 3-4". I can take pics of mine and text them to ya but I can't post online. My laptop is a pile. Joker had to post pics of my truck and motor for me lol
| | | | | Joined: Nov 2000 Posts: 1,399 Camp Commandant | | Camp Commandant Joined: Nov 2000 Posts: 1,399 | How about a different approach. Take that middle section of seat to an upholsterer and have them cut a notch or a half circle recess out of it to fit the shifter and recover it. Just a thought | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | A. I'd pull the seat out and go back to a standard seat - but I guess that's why they make chocolate and vanilla.  B. From your pictures it looks like you don't have a cable B&M shifter - looks direct linkage to me. If you gotta keep the seat then you will need to buy a new shifter.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | if you really want the seat as is I would take it and see what would be involved in cutting/notching a hole forward of where it is and off the ridge, and make it lay flat and level you might be able to do it yourself if you have the cutting skills
that might allow you enough room without having to deal with the shifter as such.
a good fabricator metal type person could fix it up for you.
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Yeah it looks like a direct linkage shifter. Drop some loot on a lokar shifter. It's $100 less than b&m but same style.
| | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | Im going to try and turn the shifter its self around if that doesn't work ill try the base of the shifter then if all else fails ill get a shorter shifter | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | | | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | I'm going to see if I can turn the shifter around if that doesn't work I'll try moving the whole shifter up.if all that fails I'll find a different shifter or rod to something that was a 4spd and a bench | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it's called a shift rod  unless you can get different lengths from where ever you got the shifter, you should be able to get some 1/4" ready rod and cut it the length you want, put the threaded fitting on one end and bend the other as appropriate .... if you'd gotten a Lokar shifter it's be easier, they supply a long rod that can be cut to length with excellent thread-on fittings for both ends Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I did that to my 52 after having the five speed s-10 installed, they used the existing shifting handle and reworked it with a curve extension, look really good
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | Im about to use a tap and die on the rod I have now and,cut what i don't need off. I had to cut a new hole in the floor to more the shifter.it's not hard but having 2 people would help so much it ain't funny.being under and in the truck at the same time | | | | | Joined: Jun 2013 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 59 | Can someone tell me which gear the trans needs to be in so I can hookup the linkage.its a Th-350 Trans.I have all gears but park,reverse but I can climb under the truck and manually put it in gear. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | Put the trans. in "Park", push the shifter as far forward as it will go, then hook up the shift rod.  | | |
