I removed the 2 small leafs, which did not do much. Is there a preferred selection to remove to lower the front. Can I remove the second longest leaf with out any fears?
. Are the straps necessary on the leafs? I like to remove the second longest, because the one on the left side is broken anyhow and causes the left side to be lower than the right.
awk
