4 members (GMCJammer51, Shade Baby, greenie-reddy, 2-Ton), 86 guests, and 1 robot.
Topics128,154
Posts1,056,834
Members48,456
any of you know of a tool or method of installing the rear wheel bearings on a 41-46 ????
?? They just press into the axle housing. You can use a wood block, PVC pipe, large socket or a brass block or dowel and tap it around the edge until seated. Are your axles good? The bearings run directly on the axle.
Axles look great,thanks
the bearings were the problem...O.D was out of spec.(to large)
or I got the wrong bearings shipped. Thanks
