4 members (gswbbc, 32Fordpuchoptop, dwreills, Otto Skorzeny), 77 guests, and 2 robots.
Topics128,035
Posts1,055,447
Members48,422
#964053 08/15/2013 11:15 PM
I changed my oil today and noticed that my drain plug was stripping out when I replaced it. I was sure to not over-tighten it and it isn't leaking but I know that I will have to come up with something before the next oil change. I am considering an expandable rubber plug or getting one of those plugs with a quick valve on it and using thread lock or even pipe tape on it and then just using the valve to change the oil after that. Any suggestions?
Gene
1959 Apache
I would try an over size plug or replace the pan
I would not put a quick valve with pipe tape on it..
Redryder pix
My Hotrod
Most auto parts stores sell a drain plug that is a little larger in diameter and looks like a pipe tap.Put a little grease on the plug screw it in, take it out and clean the grease and shavings off. install the plug, problem solved.
Tommy
59 apache 1/2t
261 short stepside
I used one of those expandable plugs years ago and it worked fine. On my present 216 I have a replacement oversized plug that cut new threads. It seems to be doing the job too. On my last change I replaced the washer with a new copper one and I didn't have to tighten it as much to get a good seal.
1951 1 Ton Completed
Thanks guys. I appreciate the advice. I will try the oversized plug. I didn't know about them before.
Gene
1959 Apache
In case you cannot find over-sized plugs locally, Chevs of the 40s has them.
Could also try a helicoil insert if allelse fails.
1940 Chevy KC 1/2-Ton
