| | | Forums66 Topics128,126 Posts1,056,353 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | I'm finally putting my 42 1/2 ton back together but forgot where the master cylinder was located and of course don't have any pictures. Any help or photo would be appreciated. Thanks | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | usually the MC can be found at the end of the pedal linkage got a shop manual? lots of pictures in this restoration blog you might find useful Bill | | | | | Joined: Apr 2005 Posts: 2,098 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,098 | Like most cars & trucks of that era it would be mounted below the cab floor on the inside of the left frame member. The frame is drilled for the mount holes and the hole in the floor will line up with the filler cap. There will also be linkage that attaches the MC to the brake pedal. Fred
