1 members (51sub), 128 guests, and 2 robots.
Topics128,125
Posts1,056,338
Members48,440
I'm finally putting my 42 1/2 ton back together but forgot where the master cylinder was located and of course don't have any pictures. Any help or photo would be appreciated. Thanks
usually the MC can be found at the end of the pedal linkage wink
got a shop manual?
lots of pictures in this restoration blog you might find useful
Like most cars & trucks of that era it would be mounted below the cab floor on the inside of the left frame member. The frame is drilled for the mount holes and the hole in the floor will line up with the filler cap. There will also be linkage that attaches the MC to the brake pedal.
Fred
