1 members (Mike Roache), 58 guests, and 1 robot.
Topics128,078
Posts1,055,938
Members48,430
#96291 07/11/2006 12:20 AM
When working on my taillights yesterday I checked my brake lights and they worked. Then I checked my turn signals and 4 ways. They worked. That's when I noticed my left brake light stopped working. Tryed turn signals and 4 ways again and then the brake light worked. Just wondering if maybe my turn signal switch is bad. It's the original one that was in the column from a '74 Buick Century. Wuddya think? Thanx
My truck: She may not be the prettiest girl at the dance, but she's all mine!
#96292 07/11/2006 12:41 AM
Easy enough to check.Use a test light at the stop light socket(bulb removed) and test for power and ground,then work your way forward to the switch.Most times it is a poor intermittent ground or loose socket.
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Think I got it fixed. I bought new taillights last year from Chevy Duty and they had 2 #61 lamps instead of 1 #1157. Adequate, but not real bright. I got a set of sockets from LMC made to convert the front parking lights to turn signals, modified them slightly and used them in my taillights. They use 1157's. Now my taillights and brake lights are nice and bright plus my left brake light seems to work all the time. Think maybe there was a bad socket in the old set-up.
#96294 09/22/2006 11:43 AM
Update. Didn't have it fixed after all. Left brake light continued not to work after using turn signal. Hit the signal again and it worked. Replaced the turn signal switch yesterday and it seems to be working now. Of course, I believe I said that once before!!
#96295 09/22/2006 10:10 PM
Riding in the Passing Lane
I think you got it this time.
1972 Chevy c10 Cheyenne Super
