1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#96259 07/10/2006 2:06 AM | Joined: Dec 2005 Posts: 19 Junior Member | | Junior Member Joined: Dec 2005 Posts: 19 | I recently (ok, over the course of the last 6 years) installed a new wiring harness.
Truck runs fine, all gauges work, BUT no lights... Headlights or Taillights. Before I start yanking bulbs and metering everything... Is there some simplestupid thing that would cause this problem?
Thanks! | | |
#96260 07/10/2006 2:28 AM | Joined: Oct 2002 Posts: 77 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 77 | First place I would check would be the headlight switch, unplug harness and use a jumper wire and see if you get anything to work that way. jim | | |
#96261 07/10/2006 3:05 AM | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I agree that's a good place to start. A simple test light can tell you if you're getting current out of the switch.
#96262 07/10/2006 3:58 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Anyone who intends to do any electrical trouble shooting needs a volt-ohm meter. They are so inexpensive it's ridiculous not to own one.
Probing around with a jumper wire is a good way to create other problems. A test light can tell you that current is there but what voltage are you getting? How are your grounds?
There are no shortcuts to electrical trouble shooting. Get a meter and start checking everything. I'd start by checking the voltage in the wire going to the switch with it disconnected. If that's good, connect it and check voltage at each out terminal with the wires disconnected. And so on until you're sure you have voltage at the light sockets. Then start checking grounds.
As I said, there are no shortcuts. Start at the source and work your way down. There's no magic about electricity. It has to follow a physical path to do it's work. Follow that path and you'll find your problem. | | |
#96263 07/26/2006 7:29 PM | Joined: May 2006 Posts: 119 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 119 | An old mechanic I worked with years ago taught me that on troubleshooting any problem just take time to think about where the source starts and follow the flow until you find the point where it stops. | | |
