2 members (Gdads51, msmall),
62
Mod | | | Forums66 Topics128,037 Posts1,055,576 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | I have a 3100 with a 4 speed and the torque tube. It was missing the u joint when I bought it and found a replacement. The first thing that popped out to me was the difference in the u joints compared to standard ones of today. This one has bushing instead of caps and roller bearings. My question is it seems as though there is a lot of play in the u joint. Is that normal or do i need to buy a replacement one with new bushings. The truck is very close to being on the road and last thing i want to happen is the u joint to fail. There is a link to a video of it below. http://s138.photobucket.com/user/cotsi95/media/chevy%203100/IMG_4690_zpscdc469f7.mp4.htmlThanks, Wade
52' Chevy 3100 5 window
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is a fair amount of side play normally. The torque tube drive shaft and U' joint bell keep the U' joint centered.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | That is what i figured but i didn't know if that was too much side play.
| | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | Anyone else have any input?
| | | | | Joined: Dec 2012 Posts: 8 New Guy | | New Guy Joined: Dec 2012 Posts: 8 | I recently had my U joint apart in my 54 1/2 ton and I don't remember mine having that much play.
Stump 1969 C-10 With - 305 C.I. Short Wheelbase - Stepside 1986 C-10 With 350 C.I.
| | | | | Joined: Mar 2013 Posts: 165 Shop Shark | | Shop Shark Joined: Mar 2013 Posts: 165 | Just installed mine, stock 3100 3 speed it had play buy not quite that much | | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | From your video, I can't determine if all that play is just end play. What kind of play do you have fore and aft? That will tell you if your bushings are not too loose.
| | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | none fore and aft just side to side.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I would say that you are in good shape. You just need to hook everything up and adjust according to the manual.
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | By the way, What does CoTsi95 stand for? For some reason, at first glance, I see CoiTus, which of course has its own specific meaning. LOL
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | I redone mine once, had the four speed with Patricks 355 ring pinion, their modified four speed sagnaw... drove that sucker for about eight yrs with the enclosed tube.......then one day I popped the clutch on an incline with a driver about a foot behind me,heard a pop and the truck would not moved...towed it home and appeared the the u joint was the problem.. I replaced it, took a while because I had it in the street, by my self and me not being a mechanic, got er done... took it for a test drive and all was sweet... I was so proud of myself..........next day I was driving to work and ever thing came unglued....finally got to work and limped home in second gear...............
I decided it was time to install s-10 five speed, local shop did the work.......... imagine that.lol......best decision I ever made.. almost double the gas mileage... a lot lower rpm at 70 or how ever fast I wanted to drive it........I am sure you will have better luck then I did....
the shop guy said the u joints looked ok... so guess the problem must have been in the rear end, replaced that booger with a blazer... Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | By the way, What does CoTsi95 stand for? For some reason, at first glance, I see CoiTus, which of course has its own specific meaning. LOL Haha i get that a lot but really its a user name ive had for a long time. I just use it on every forum. I have another car that ive done a lot of work and modifying too and it saids for that. CO = colorado TSI= my turbo awd eagle talon 95= 1995 (year of my talon) I pronounce it CO..T..S..I
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I wouldn't take offense if I were you. My interpretation of your user name says more about me than it does about you.
| | | | | Joined: Feb 2012 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2012 Posts: 50 | No offense taken. It's a pretty unusual user name unless your around a certain type of car. Most people pronounce it cot-si.
