3 members (Steveoreno, moparguy, carbking), 58 guests, and 5 robots.
Topics128,179
Posts1,057,162
Members48,465
Do the aftermarket A/C-heater kits utalize/mount with any of the original mounting holes from the stock heater? What about for the hoses? This will be for a '57 GMC. I'd like to fill in any unused holes in the firewall if i can and keep it as clean as possible. Do they typically use the same fresh air intake hole on the kick panel as the heater does?
totally depends on the aftermarket unit you get, usually you can use the hose holes, although which ones you have present depends on what heater the truck originally had, you'll find 'stamped' marks on the inside insulator pad for different configurations - better get the heater you want before filling any holes wink
