| | | Forums66 Topics128,115 Posts1,056,624 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 23 | I have been working on a 66 chevy c60 2 ton dump truck. Found the parts and got the brakes working. It took some time to find the numbers,and it was a bit frustrating. I posted the part numbers in the swap meet section under parts for sale. I do not sell them, but did not want to post them in the wrong place and have them removed. And I wanted to share them in the hopes it will make someone esles job a bit easier, in the future. | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | ckell, It's OK to post part numbers for parts you have researched here. The Swap Meet section purges the old post so the info isn't saved for others to see down the road. Mike B  | | | | | Joined: Jul 2013 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 23 | If it saves somebody some time, I'll post it here also. Its better to be bust'n knuckles on the truck than pounding a key board looking for parts. Master cylinder cluch and brake togather.Napa # P34404 Hydrovac master cylinder. Napa #51-8052 Brake shoes rear # UP442R Here is a web site as well; http://www.autoatlanta.com/centric/...0MD&model=C60%20C6D042&year=1966 Rear Wheel Cylinder Kit two per side #M34403
