9 members (Gdads51, 52Carl, fonz8261, greenie-reddy, 2-Ton, Forty9, RoadsScholar, mk72, 1 invisible),
138
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,125 Posts1,056,343 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | First time with real miles on the truck last weekend. On return trip I sensed (with ears and seat) a hi frequency rumble at/about 47 MPH. Subsided above 47 and did not appear below (for the most part). Occurred both while accelerating and decelerating. Did not feel through the steering wheel, but felt through the cab and in the seat. Truck handled normally throughout speed range. Thought maybe motor or transmission at first, but took it out of gear and let it coast through the speed range and it occurred as well. Now thinking bad tire or rear axle. Once stopped at destination rear/passenger side hub cap was warm (not hot) while all others were ambient temp. Anyone able to refine my troubleshooting and give me some ideas? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Make sure that brake is not adjusted to tight. There are a lot of things that can cause noise from tires to...
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Had not thought of that. Thanks for thoughts.
| | | | | Joined: Sep 2006 Posts: 335 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 335 | | | |
