5 members (Gdads51, TUTS 59, MickeyP, tclederman, 1 invisible), 75 guests, and 1 robot.
Topics128,049
Posts1,055,695
#961367 08/05/2013 5:52 PM
I am sure this is not normal. the adjustment in the shop manual says to screw it up or down. Has anyone had to fix this? how did you do it?
thanks steve
http://i1321.photobucket.com/albums...%20Truck/uppercontrolarm_zpsdef0fd8e.jpg
You're going to need to remove the upper support from the column, and take the upper part of the rod apart from the clamp. You'll then be able to turn the upper support to adjust it up on the threads. IIRC, the dimension should be approximately 1/16" from the bottom of the shift lever to the top of the support with the trans in neutral.
Bill Burmeister
Does the threaded part of the shifter move in and out of the support when you lift up on the shifter?
I suspect you need a new support. Over time the threads wear out.
My Blog
I just did, the part that bolts to the steering column has all the threads stripped, is there an aftermarket i can purchase to replace it?
Found it at classic parts YEA!
also found a rebuild kit for the knuckle section of the shifter at bowtie bits antique truck parts
