2 members (3B, Cosmo),
149
Mod | | | Forums66 Topics128,080 Posts1,055,951 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | while stripping down my 42 torque tube rear end I found the l/h E-brake cable cut inside the drum. the arm the cable clevis attaches to is missing along with the rod and spring that attaches to the front brake shoe.....R/H is intact. I'd like to find the parts and install during rebuild but I've not found anything in my internet searches. The 42 shop manual calls these parts the Toggle Lever and Extension Link My question.....how may years did Chevrolet use the same parts I am missing?
some help please
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1936-50 pass and 1/2 ton should all be the same.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | thanks Dave, that may make these parts easier to find
