0 members (),
117
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,089 Posts1,056,141 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 101 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 101 | I need to get tires for the 45 1.5t that I just got going. Can see belt through the slicks(treads long gone). It has 7.50 x 20 on the fronts and 8.25 x 20 on the rears. I can't find many 7.50, is that the correct size for my truck?
1946 1/2 ton - 1962 "261" 1953 1/2 ton 5-window - "235" 1955 1/2 ton - 55 "265" Corvette motor 1959 1/2 ton Fleetside - "283"
| | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Have you tried to see if Coker has them available?
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Dec 2010 Posts: 253 Shop Shark | | Shop Shark Joined: Dec 2010 Posts: 253 | Most likely the rear tires were also 7.50 x 20 from the factory. The supply of 7.50 traction tires has all but dried up except for the NDT military tires so people began to use the more readily available 8.25 traction tires on the rear. If your trucks gearing and motor are currently happy with 8.25's and it's not lugging and it is a two wheel drive truck then a new set of 8.25x20's should be OK.
-Mike-
1945 Chevrolet G 506 1.5 Ton Military 4X4 1967 Jeep Cj5 with 283 SBC
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Normally these trucks were spec'd with a tire size larger on the rear. If you look at the load capacity chart at the rear of the yr. specific drivers manuals for these trucks, you'll see the listings. That truck of yours could have very well came from the Factory with 7.50, front, 8.25 rear. Most all of the Chevrolet 2 ton trucks I've had through the years were this way. I always tried to install 8.25, all the way around. To know for sure, i'd buy a 1946 Chevrolet Truck Operators Manual, & see what it says.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Give these guys a call. http://www.nebraskatire.com/truck I have bought from them. My 46 GMC 303 which is a 1 1/2 ton has 700x20 on it which was probably what they came with. A 7.50x20 which is still readily available was a common replacement. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Kenneth,
Thanks for that link.
What does the E refer to after the size? I will need two 9.00 x 20" for my 54/55 2-ton GMC COE and could only find a few sources at much higher prices.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | If you are in the market for 9.00x20 tires with 6 lug Budd style wheels, another low cost option is used military 2 1/2 ton truck tires. Many of the guys in that crowd are using larger singles on bobbed trucks and the 9.00x20 tires are unwanted so they sell for cheap and the wheels fit GMC's. Of course, the tires are Non-directional tread. I looked at this option for my 41 military Chevy, but they are a little too tall. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Thanks, Paul
The wheels have 10 bolts. I'll be also be looking to buy two "spare" wheels, but I have not measured the hub-hole in the center of the wheels.
I want new rubber on the two "new" front wheels. I'll use the old/wheels tires for spares (the rubber has a little cracking on one side - they should be OK for spares.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Tim,
Sorry, I thought the 2+ton trucks were all 6 lug, especially the GMC's. Learn something every day. I have 2 two piece ten lug wheels from a 51 Chevy 1 1/2 ton I got in a trade and are no good to me if you are interested.
I understand about going for new rubber especially in the front. Short cutting with worn cracked tires is a recipe for disaster. I recently "bit he bullet" and bought 7 new 7.50x20 NDT's. Ouch!
Paul
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Pete's Tire Barn has 8.25 and 9.00 - 20 truck radials at a good price. I didn't check on 7.50 and I don't know about bias.
I decided to do 8.25 all around on the 2 ton. That is the biggest that will fit in the front on stock rims.
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | Tim, I'm not really sure what the E means. There is a load range E that would be about the capacity of these tires, but the best thing would be to call them. They are in rural Nebraska and are old country boys willing to help. | | | | | Joined: Dec 2011 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2011 Posts: 90 | i thought the 2 tons had 9.00 x 20 | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The factory spec sheet (1-1/2, 2 ton) showed 7:50 x 20 and 8:25 x 20 on the original rims. A later addition to the spec sheet were 9:00 x 20 on "DOT" rims. 7:50 fronts and bigger rears were common.
| | | | | Joined: Nov 2011 Posts: 18 New Guy | | New Guy Joined: Nov 2011 Posts: 18 | Mark, looking at the list of trucks on your signature, I must be missing why you're asking the question, but just in case... Your original question was "is that the correct size for my truck?" I would suspect the answer as one of the other posters inferred is on the GM Heritage site in the online Vehicle Information Kits (original specification manuals). Here is the link. Make sure you scroll down the page to see the online document links. http://www.gmheritagecenter.com/gm-heritage-archive/vehicle-information-kits.htmlSee if this helps. | | |
