| | | Forums66 Topics128,264 Posts1,058,356 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I replaced the manifold gaskets on my '46 235 a few weeks ago. I've driven the truck maybe 150 miles and it's leaking again. I have tightened the mounting bolts several times and it sounds better for a day or two, then they're loose again. The manual just says to make them tight, there is no torque specification. How do I keep the bolts from loosening? | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Have you had this manifold off? Did you check its edge for flatness? I would bet that yours is warped a bit and probably will never seal unless you have that edge planed. Jerry Jerry
| | | | | Joined: Jul 2011 Posts: 36 New Guy | | New Guy Joined: Jul 2011 Posts: 36 | I also have a 51 Chevy 1/2 ton, 235. Have replaced the exhaust manifold gaskets and have tightened and retightened. How would one go about having the manifold edge planed? I am with the idea that a machine shop can check for the flatness and can plane the edges. Am I correct? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | most good machine shops can plane the surfaces. You should check first to make sure the two manifolds are bolted together with the faces in line. I see a lot that are not.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | Well, I finally tore into the project today. I only had to drill out and retap 3 bolt holes. The manifold checked out nice and flat when I checked it with a straightedge. Since the gasket set included the one that goes between the manifolds for the heat riser, I took them apart and reassembled them to the engine before tightening anything. Everything went together well and it runs quieter than ever. I'll let you know in a few weeks how well it holds up. | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Just my 2 cents on this: Undoing the bolts at the heat riser allows each manifold too set better against the head. When the heat riser is tightened up all of the misalignment is taken up at the junction of the heat riser and not at the head. It worked wonders on my 235. I had to remove and replace the exhaust manifold due to some broken bolts. With the manifold apart I could check each piece for true and flat at the head flanges. Intake was good and exhaust was good. When they were bolted together they were not. Kid of a twisted and misaligned if you will. So I put them on while the heat riser bolts were loose. Worked very well. Snugged up the heat riser bolts and nothing moved. Started and was quiet. No more leaks. Drilling and re-tapping holes? Good argument for anti-seize for sure.
Steve H
