2 members (Buckeye998, J Lucas), 301 guests, and 2 robots.
Topics128,152
Posts1,057,012
Members48,460
#960869 08/03/2013 10:38 AM
I am having trouble with this. I have started the motor several times and I think the solenoid finally has failed. I have replaced the ignition switch. So I know that's good.
My question is. The way it was originally wired there was a main power from the battery. And power back from the ignition switch to the post labeled S. "not using foot start". There was nothing ran to terminal labeled R.
Can anyone clarify what should be wired to this terminal?
Thanks in advance.
1950 Chevy 3600
the R terminal is for the resistor bypass used for 12V, nothing to do with the solenoid or starter function
Thanks. I don't have that. Should I install one. My system is 12 v. How do you wire that and what size of resistor do I need.
1950 Chevy 3600
with 12V you should either have an ignition resistor [from a FLAPS, one listed for a 58, any model or engine], or an internally resisted coil [easier], which should be available as Echlin #IC21 or Napa #IC14 [I=internal] - check a wiring diagram for 56 up to see how the resistor and bypass are set up here
the ignition resistor cuts the voltage to the coil to increase points life, and bypassing it while starter is engaged insures fatter spark under the starter loading, so easier starting
Thanks red. I appreciate the help. Any thoughts on my other thread. I'm having a rough morning with this. Lol
1950 Chevy 3600
