3 members (baldeagle, cmayna, Gray_Ghost), 61 guests, and 5 robots.
Topics128,017
Posts1,055,338
Members48,419
#960352 07/31/2013 10:03 PM
I just installed my overdrive in a 58 chevy 3100 half ton. I am having problems with the linkage connecting. Can I use the side cover from my stock three speed on the overdrive. Will the stock 4 bolt cover work with the lock out rod ?
6571 #960463 08/01/2013 11:18 AM
If both have 4 bolts the covers should interchange. The lockout is just a rod that the reverse lever pushes. Nothing different about the cover or internal parts of it.
6571 #960464 08/01/2013 11:22 AM
You can use your existing 3 speed side cover on an OD trans with a 4 bolt side cover. You probably got an OD from a car which has a different configuration on the shifter arms. The 58 side cover will work fine with the lock out rod. Be sure to check the 2/3 shift fork when you have it apart. It is a normal wear point on these 3 speeds and is a contributor to popping out of 3rd gear.
Fred
Got the side cover changed and the overdrive is in. Gears shift smooth, and all of the electrical has been connected according to the wiring instructions and diagrahm that Cletis provided a while back. Will be test driving tomorrow to see how she moves on down the road. Look forward to the decreased RPMs. Thanks guys for all of the info.
6571 #960522 08/01/2013 5:01 PM
ODSS President
ODSS President
non overdrive : overdrive = night : day
~ Cosmo
1949 Chevy Half Ton
6571 #960578 08/01/2013 9:26 PM
Gas Pumper
Gas Pumper
Good stuff! In case you don't know it already, you can find the complete documentation on the Borg overdrives on my web site.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
6571 #960591 08/01/2013 10:16 PM
ODSS President
ODSS President
Deve,
Have referenced your site many times, thanks.
Cosmo
~ Cosmo
1949 Chevy Half Ton
Cosmo #961210 08/04/2013 9:33 PM
Did the test drive today. The engine runs so much cooler. I did not get all of the heat from the engine inside the cab. The free wheeling part is going to take some time getting used to and my mind has been changed about the brakes also. It is indeed time to start collecting parts for a disk brake conversion. Truck moves along with a lot less effort and stress on the engine.
6571 #961218 08/04/2013 9:55 PM
Congratulations on your success. The more you drive it, the more you'll love it.
I lock mine out of OD when I'm in a town to minimize the free wheeling.
Cletis #961224 08/04/2013 10:05 PM
Cletis do you still have the drum brakes on your burb, if so how well does it stop?
6571 #961228 08/04/2013 10:11 PM
Not cletis, but I have a virtually identical setup in my '55 3200. I lock mine out in town as well, for the same reason. I'm still running stock drums, no power assist, stops just fine. The trick is to keep them properly adjusted.
Bill Burmeister
I will re-adjust mine also. Driving in town with it locked out is good advice. I think I am just use to down shifting to assist when stopping. I have a few days off this week so I will be driving the truck a lot more on the interstate to get used to the overdrive.
6571 #961234 08/04/2013 10:41 PM
6571, what kind of RPM drop did you get with the overdrive?
Brian
Brian
1955.2 3100 Truck
6571 #961235 08/04/2013 10:41 PM
I have power front discs on the Suburban. I love it.
55shaker #961238 08/04/2013 10:55 PM
I don't have a tach in the truck but I can tell it is not sounding like it is maxed out at 60 mph. It's a lot like driving a stovebolt belair but just not as soft of a ride. That engine that sounds like its running 90 mph and you are only doing 60mph is gone. The engine sounds like 45 and you're doing 55-60. I like that.
Cletis that power disk must have required a bit of alterating. Did you keep the floor pedals or go to the swing set brake and clutch pedals.
6571 #961327 08/05/2013 1:41 PM
I kept the floor pedals. Here's info on the swap.
