0 members (),
188
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2010 Posts: 146 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2010 Posts: 146 | My truck came with stock 6 lug 15" rims, which should be 5.5" wide. Does anyone know if 235/75/15's will fit on them? Is that too wide? Thanks | | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | My tire dealer told me to use 235/75/15's on my 15" rims. Check with your local tire dealer for his recommendation. Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 235s work best on 6-7 inch wide wheels. On a 5.5 inch wheel, there could be issues with wandering and tire stability. A 215/75/15 would be a better fit, and is very close to the stock 6.70-15 in overall size.
Bill Burmeister | | | | | Joined: Oct 2010 Posts: 202 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 202 | Does anyone know what the overall diameter of the 6.70/15 tire was. I am thinking of going with a 205/75/R15 to go my 5" wide stock wheels. I would like to insure I am getting the proper height.
Thanks in advance Walt Williams La Verkin, UT
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Walt,
What year 6.70/15 tire?
The rolling diameter in 1952 was about 26.7" The unloaded diameter was about 28.1"
