3 members (dt235sd, Bwana-Jim, Hugh63c10), 116 guests, and 1 robot.
Topics128,211
Posts1,057,468
Members48,471
Hey guys this is my first post. I haven't found a solution to this yet. I have a 55 first series pickup with the stock 3 speed and 235. I have dual Fenton carbs setup on the 235. Here's my question. What have you guys done for power brakes on the 3speed. Firewall mounting isnt really and option since I have the Fenton. I'm running disc brakes up front and plan on putting discs on my 70 Camaro rear end. Any help would be appreciated
Red dot, center of chest ...
On my '48, the booster is mounted on the frame under the floor on the driver's side. I have four wheel power disc brakes.
Paul Schmehl CI 6
geek@stovebolt.com
Stovebolt Staff: Geek
Did you have any issues with the clutch linkage? I just don't wanna drop cash on something that wouldn't fit . A lot of the booster/cylinder/ pedal assemblies I've been looking at say for auto trans only
I did not. I'll try to get under the truck tomorrow and get the brand. (It's been a while. I don't recall all the details.)
Paul Schmehl CI 6
geek@stovebolt.com
I'm running the Performance On Line kit in my '54 burb with 3 speed overdrive. No problems with clutch linkage or tranny clearance. I did run into some other problems though.
What kind of problems? I crawled unde rthe truck yesterday and it looks like i can move about 6 inches back from the original M/C and that would clear everything
Problems with the bracket not fitting the frame among others. Click the link.
1 Offline
Anyone add duel master cylinder with power booster to stock brakes?
On my '55 2nd series with a stock 235 and 3 speed manual trans I used an ECI power front disc brake setup with my stock rear drums. Double 8" booster pushed the new dual master cylinder back so I had to cut a new access hole in my floor. I then put my bench seat on hinges to make it easier to access the cover. Yes, the stock 235 generates enough vacuum to service the booster. I probably did not need the booster but it now stops like my wife's BMW. Photos are at www.picturetrail.com/motthollow.
George C.
'38 chevy radical street rod project, '42 GMC pickup resto-rod project, '55 2nd series pickup on the road, '56 custom sedan delivery next in line to hit the streets. www.picturetrail.com/motthollow
Good job guys. Great work. I feel more confident now that others have made it work
Hey everyone, so i purchased every thing tgis week and started installing, ive already ran into a problem with the clutch linkage. I purchased a kit on ebay from nelcohotrods which had no disclaimer saying not for standard trans. I got the brackets and stuff installed no problem. the problem is this has to have been made for an auto trans or something since that "post" for the clutch and brake swing arms (whats the correct term for that part) isnt big enough to accommodate both the clutch and brake arms like the original. ill post a link to pictures to show you what im talking about, i emailed the seller to see if they had a solution for me. im thinking maybe i can remove the post entirely then drill a hole into the bracket to put the original post back on, or maybe cut off some of the bracket to expose more postto it, the other thing thats wierd is this "post" also had a threaded hole in it , almost like you can extend it with another post. let me know if you guys have tried any of this before. im desperate to finish these dang brakes
Heres the link to the pics
http://s1071.photobucket.com/user/Jovani_Griego/library/
