| | | Forums66 Topics128,181 Posts1,057,187 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | I was reading on line at inliners.org/ they had a tech tip for doing a full pressure oil filter change over. At the end of the article he mentioned the pressure would be 60 psi when cold and at hwy speeds and 30 psi at idle. Is there a pump that puts out hat much pressure? For my 1956 car motor only a 35 psi was listed. The truck motor was 45 psi. Thaanks Sharon | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | 35 psi for the car is probably due to the fact it has Hydraulic lifters. The hydraulic blocks have have larger oil passages and divert more oil to the cam and lifter assembly. The trucks would have mechanical lifters. My service manual shows the later 58-62 engines only running at 35 psi also. All the 58-62 blocks were drilled for hydraulic lifters regardless if it was a hydraulic of mechanical application. | | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I have a 58-62 235 engine that has hydraulic lifters and was drilled out for the full flow oil filtration. It pegs my cab 30 psi gauge. I need to add an inline 100 psi gauge to see what the oil pressure is.
Dennis -there is nothing stronger than the heart of a volunteer-
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | the gauge in the full pressure trucks only goes to 60 psi. I may be wrong, but I am pretty sure the relief lifts at 45 psi. The GMC oil pumps are set at 60 (?) however. | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Would it be ok to put a 60 psi pump in my car/truck engine? It runs 25 to 30 psi hot on the hwy. Thanks Sharon | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I don't know if there is such a pump. Your pressure doesn't seem like a problem to me. | | | | | Joined: Jun 2013 Posts: 148 Shop Shark | | Shop Shark Joined: Jun 2013 Posts: 148 | Well it's got 3,000 miles on the rebuild. I just won't worry about it. Daily driver just keeps on truckin. Sharon | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | yep that's about what they run. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Pumps do not make pressure, pumps create flow. The passages and restrictions create pressure.
Melling and many others sell HIGH VOLUME pumps.. the gears that move the oil are longer giving more displacement per rotation.
So yes, you can get a high flow pump and increase the system pressure. It won't lube any better, and may actully be detrimental as some parts are splash lubed.. to much pressure may alter that.
Typically 20-30% GPM flow increases are what you find for high volume pumps. | | | | | Joined: Jul 2013 Posts: 200 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 200 | Pumps do not make pressure, pumps create flow. The passages and restrictions create pressure.
Typically 20-30% GPM flow increases are what you find for high volume pumps. Correct, the pressure is determined more by the bearing clearances, or as has been mentioned, a restriction to flow, than anything. The tighter the clearances, the higher the pressure.
We cannot solve our problems today using the same thinking we used when we created them! Albert Einstein
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | There is no high volume pump for the 235 - the factory (and Melling replacement) 1955 pump is the largest, and with some work can be retro-fit into earlier engines. The pump pressure is whatever the relief valve spring says it is, or less. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | GMC oil pumps will physically fit, they have 60 PSI relief settings, and are quite a lot larger than the chevy pumps. You would probably need to fabricate your own oil lines and pickup. I am not certain of the volume, but it appears to be big enough that you might actually get or approach the relief setting. All the old hot rod manuals say to use them for more oiling. But unless you are turning it 5000 RPM it really won't be necessary. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | In my L134 Go Devil you can change the relief pressure (and to a point, system pressure) by shimming the relief spring in the pump.
I'd still stay within specs as increasing pressure does not necessarily increase flow.
Someone said CAM bearings can cause low pressure... I believe that its mostly main and rod bearings. Cam bearing generally don't wear nearly as fast as anything connected to the crankshaft.
Also, as noted, using a heavier weight oil will bump pressure up... but again, you really want FLOW... a thick oil may read as high pressure on the gauge, but not be flowing anywhere near as fast as needed.
Stick with 30 weight oil, the book says as long as you read a non-zero number (like 2-3psi) at idle you are good. If it drops then consider new main/rod bearings as they are the real culprit. | | |
