6 members (Donf, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost), 120 guests, and 1 robot.
Topics128,056
Posts1,055,799
#959750 07/29/2013 2:31 PM
Is it possible to change the 'stomp start' gear to one for a 168 tooth ring gear?
I'm finding all sorts of 168 tooth flywheels, but cant locate a 139 tooth ring geared flywheel for the six bolt crankshaft.
Thanks!
Tom
abxtc #959759 07/29/2013 3:22 PM
Are you using 6 or 12 volts?
If you are using 12 volt than a 1955-59 truck is 12 volt and stomp style and will work. You will need the whole starter, not just the drive.
My Blog
abxtc #959762 07/29/2013 3:37 PM
I'm going to have a 6V flywheel with good ring available soon, converting to automatic.
abxtc #959793 07/29/2013 7:03 PM
Thanks for the replies! I'm sticking with 6V for now, I understand those starters like the 12V.
Jim, your flywheel is six bolts to the crank, and how many for the clutch?
I'll PM you is you don't mind, and we can hash out the details.
Thanks!
Tom
