7 members (1955 1 Series, Lightholder's Dad, 55shaker, DuckRancher, Jon G, TexasA&M48Truck, 1 invisible),
70
Mod | | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 18 New Guy | | New Guy Joined: Jul 2013 Posts: 18 | Hey guys this is my first post. I haven't found a solution to this yet. I have a 55 first series pickup with the stock 3 speed and 235. I have dual Fenton carbs setup on the 235. Here's my question. What have you guys done for power brakes on the 3speed. Firewall mounting isnt really and option since I have the Fenton. I'm running disc brakes up front and plan on putting discs on my 70 Camaro rear end. Any help would be appreciated | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | On my '48, the booster is mounted on the frame under the floor on the driver's side. I have four wheel power disc brakes. | | | | | Joined: Jul 2013 Posts: 18 New Guy | | New Guy Joined: Jul 2013 Posts: 18 | Did you have any issues with the clutch linkage? I just don't wanna drop cash on something that wouldn't fit . A lot of the booster/cylinder/ pedal assemblies I've been looking at say for auto trans only | | | | | Joined: Mar 2000 Posts: 1,184 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,184 | I did not. I'll try to get under the truck tomorrow and get the brand. (It's been a while. I don't recall all the details.) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I'm running the Performance On Line kit in my '54 burb with 3 speed overdrive. No problems with clutch linkage or tranny clearance. I did run into some other problems though. | | | | | Joined: Jul 2013 Posts: 18 New Guy | | New Guy Joined: Jul 2013 Posts: 18 | What kind of problems? I crawled unde rthe truck yesterday and it looks like i can move about 6 inches back from the original M/C and that would clear everything | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Problems with the bracket not fitting the frame among others. Click the link. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | Anyone add duel master cylinder with power booster to stock brakes? | | | | | Joined: Jul 2009 Posts: 9 New Guy | | New Guy Joined: Jul 2009 Posts: 9 | On my '55 2nd series with a stock 235 and 3 speed manual trans I used an ECI power front disc brake setup with my stock rear drums. Double 8" booster pushed the new dual master cylinder back so I had to cut a new access hole in my floor. I then put my bench seat on hinges to make it easier to access the cover. Yes, the stock 235 generates enough vacuum to service the booster. I probably did not need the booster but it now stops like my wife's BMW. Photos are at www.picturetrail.com/motthollow.
George C. '38 chevy radical street rod project, '42 GMC pickup resto-rod project, '55 2nd series pickup on the road, '56 custom sedan delivery next in line to hit the streets. www.picturetrail.com/motthollow | | | | | Joined: Jul 2013 Posts: 18 New Guy | | New Guy Joined: Jul 2013 Posts: 18 | Good job guys. Great work. I feel more confident now that others have made it work | | | | | Joined: Jul 2013 Posts: 18 New Guy | | New Guy Joined: Jul 2013 Posts: 18 | Hey everyone, so i purchased every thing tgis week and started installing, ive already ran into a problem with the clutch linkage. I purchased a kit on ebay from nelcohotrods which had no disclaimer saying not for standard trans. I got the brackets and stuff installed no problem. the problem is this has to have been made for an auto trans or something since that "post" for the clutch and brake swing arms (whats the correct term for that part) isnt big enough to accommodate both the clutch and brake arms like the original. ill post a link to pictures to show you what im talking about, i emailed the seller to see if they had a solution for me. im thinking maybe i can remove the post entirely then drill a hole into the bracket to put the original post back on, or maybe cut off some of the bracket to expose more postto it, the other thing thats wierd is this "post" also had a threaded hole in it , almost like you can extend it with another post. let me know if you guys have tried any of this before. im desperate to finish these dang brakes Heres the link to the pics http://s1071.photobucket.com/user/Jovani_Griego/library/
