1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#959350 07/27/2013 5:26 PM
any one have a part number for an eternal coil with built in resistor. I am switching to 12 volt on my 52 with 1957 235 motor. dont want to use external resistor.
Paul
wodniw5 #959353 07/27/2013 5:47 PM
'eternal' coil? like one that's good forever and ever? grin
head to your local NAPA or any FLAPS and ask for one, or try a tractor supply, almost all tractors use'em
wodniw5 #959361 07/27/2013 6:39 PM
been to napa advance and autozone also o'riely auto parts. all keep giving me external coils. teling me I have a generator on a 1957. I tell them I switched to alternator and 12 volt Wish I had some old timers like me working there
wodniw5 #959364 07/27/2013 6:50 PM
Tell them you want a coil from a 60's V8. Should get you what you want. Any good parts man will know what an internal resistor 12 volt coil is without even looking in the computer.
wodniw5 #959366 07/27/2013 6:53 PM
amen. i tried all above getting stone walled. going to try monday only new kids work weekends
wodniw5 #959378 07/27/2013 7:20 PM
yeah, kids - generator/alternator makes no difference, amps is amps, 12 volts is 12 volts .... at my NAPA here they'd ask if you want internal or external, even with a 60's V8, sometime in the 60's they went to the 'hidden' resistance wire to replace the ballast resistor
wodniw5 #959382 07/27/2013 7:37 PM
I think NAPA has a couple that'd do well, an Echlin ECH IC21 or a Proformer MPE IC21SB. That is if you like the round style.
Bruce
wodniw5 #959410 07/27/2013 9:52 PM
Can I ask why you want to use a coil with an internal resister?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Mike B #959447 07/28/2013 12:22 AM
The one you want is NAPA IC64.
'52 Chevy 3600
'03 Chevy 2500HD
'64 Pontiac Grand Prix
'93 Jeep Wrangler
wodniw5 #959477 07/28/2013 10:02 AM
thanks for napa number. going to pick it up
