7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl),
112
Mod | | | Forums66 Topics128,049 Posts1,055,665 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | I've read all the threads, and I realize there is some disagreement about the "correct" gray. I like the relatively lighter JC gray (PT115) but they are out of stock with no firm date.
Meanwhile, Classic Parts has a specially mixed gray, part no. 88-005. They say it is correct, but there is no paint chip. Best the staff could do is to tell me it is a "medium to light" color. Has anyone used this specific paint, and can you describe it? Thanks!
Harry | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | why not get a qt of white and one of black and mix your preferred shade out of the brand you want?
| | | | | Joined: Jan 2011 Posts: 159 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2011 Posts: 159 | That would double the cost. All I want is the JC color, available now. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Bill Hirsch Automotive Paint Products does the best job I have seen so far on giving you the correct gray in spray cans. http://www.hirschauto.com/If spray cans are a problem, they also do it in cans. They have been doing this forever so they know the proper colors. Hope this helps. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I have used the Bill Hirsch "medium" grey paint, bought a quart. Brushed it on the block, looks great. Put some in a HVLP gun, and sprayed the valve cover, looks fantastic.. Highly recommend this paint, quality! | | |
