3 members (Otto Skorzeny, Woodcmiami, Steelonsteel), 52 guests, and 3 robots.
Topics128,052
Posts1,055,773
#957837 07/21/2013 12:04 PM
Hi - I took apart my windshield, cleaned, blasted and repainted the frame and now want to reinstall the (original, maybe) glass. It had a bit of rust damage but was salvageable - the link bars were unusable and it had a few rust throughs in the inside channel on the bottom. I por15'd the channels to hopefully prevent the frame from continuing to rust.
I bought setting tape (1/32) from chevs of the forties and d-day is approaching for glass reinstall.
Anyone have helpful hinds to make this as painless and cheap as possible? I have made a paper template in case I break it, and have read it described as putting socks on a rooster.
I have read to use the thinnest setting tape and lube it up with wax remover first, then tap I with a wood block and rubber mallet to sit in down. I have also read to not use setting tape at all but hockey or electrical tape which I would think wouldn't seal (not that I'm planning on taking her underwater).
Any opinions/pearls on putting socks on this rooster?
I just set the headliner in my GMC yesterday and prelubed the metal and the runner with a bead of Dawn (original) and it all slid right into place. I'll be using the same lube when I set my other windows. cleans up with a wet paper towel.
Give me ambiguity
or give me something else
Yeah. My son owns a big body shop and only works on high-dollar cars & trucks. He uses liberal amounts of Dawn on all his glass
installations that use a rubber gasket.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
I'll try dawn on the outside rubber gasket. Thanks for the suggestions.
If you have issues with the setting tape, I'd suggest taking glass & frame to a local auto glazing shop. They can install using polyeurethane glazing compound. Cost me around $ 50.00
1940 Chevy KC 1/2-Ton
