3 members (KEVINSKI, Bill Hanlon, JW51), 229 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
I am installing a 67-72 Tilt Automatic Steering Column in my 61 Apache.
I have a Neutral Safety Switch on the steering column. However, I do not have a clue what wires get connected to this Neutral Safety Switch.
Can anyone provide me with clear direction on what wire(s) need to be connected to this switch?
Your wife called & said
"buy whatever you want"!
1961 Chevy Apache 10 Restoration Photo Album
in the Gallery ...
My 1961 Chevy Custom Apache 10 SWB
Heres what I have - looking down the column from the steering wheel, I have ( 4 ) connection prongs. Two are side by side / two are vertical.
On the side by side, left hand is power feed for backup lights / right hand goes to backup lights.
On the vertical, upper goes to solenoid / lower goes to ignition switch. Hope this works - I haven't got my truck back on the road yet to test in real life !!!
1940 Chevy KC 1/2-Ton
Riding in the Passing Lane
Britcon is right. The original wires are purple about 12 gauge. Some of the older models had the switch down on the trans. with a little rod hooked to the linkage.
1972 Chevy c10 Cheyenne Super
Here's one for you. I installed a new neutral safety switch on my column, put the wires back like they were, hit the ignition switch and up came a big ball of smoke. It fried a wire going to the starter. Now I have to use a push button switch to start it. Just one of the joys of driving an old truck!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
