| | | Forums66 Topics128,088 Posts1,056,122 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95792 06/02/2006 4:51 AM | Joined: Mar 2006 Posts: 114 'Bolter | | 'Bolter Joined: Mar 2006 Posts: 114 | I am installing a 67-72 Tilt Automatic Steering Column in my 61 Apache.
I have a Neutral Safety Switch on the steering column. However, I do not have a clue what wires get connected to this Neutral Safety Switch.
Can anyone provide me with clear direction on what wire(s) need to be connected to this switch?
Thanks | | |
#95793 06/02/2006 4:15 PM | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Heres what I have - looking down the column from the steering wheel, I have ( 4 ) connection prongs. Two are side by side / two are vertical. On the side by side, left hand is power feed for backup lights / right hand goes to backup lights. On the vertical, upper goes to solenoid / lower goes to ignition switch. Hope this works - I haven't got my truck back on the road yet to test in real life !!! | | |
#95794 06/02/2006 9:43 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Britcon is right. The original wires are purple about 12 gauge. Some of the older models had the switch down on the trans. with a little rod hooked to the linkage. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#95795 06/10/2006 4:53 PM | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | Here's one for you. I installed a new neutral safety switch on my column, put the wires back like they were, hit the ignition switch and up came a big ball of smoke. It fried a wire going to the starter. Now I have to use a push button switch to start it. Just one of the joys of driving an old truck!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
