2 members (porsche, Dennys28),
93
Mod | | | Forums66 Topics128,051 Posts1,055,766 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | Hi - I took apart my windshield, cleaned, blasted and repainted the frame and now want to reinstall the (original, maybe) glass. It had a bit of rust damage but was salvageable - the link bars were unusable and it had a few rust throughs in the inside channel on the bottom. I por15'd the channels to hopefully prevent the frame from continuing to rust. I bought setting tape (1/32) from chevs of the forties and d-day is approaching for glass reinstall.
Anyone have helpful hinds to make this as painless and cheap as possible? I have made a paper template in case I break it, and have read it described as putting socks on a rooster.
I have read to use the thinnest setting tape and lube it up with wax remover first, then tap I with a wood block and rubber mallet to sit in down. I have also read to not use setting tape at all but hockey or electrical tape which I would think wouldn't seal (not that I'm planning on taking her underwater).
Any opinions/pearls on putting socks on this rooster?
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I just set the headliner in my GMC yesterday and prelubed the metal and the runner with a bead of Dawn (original) and it all slid right into place. I'll be using the same lube when I set my other windows. cleans up with a wet paper towel.
| | | | | Joined: Jan 2013 Posts: 603 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 603 | Yeah. My son owns a big body shop and only works on high-dollar cars & trucks. He uses liberal amounts of Dawn on all his glass installations that use a rubber gasket.
57 GMC LCF 370 55 John Deere 40-W 59 John Deere 430-W 2000 GMC 4x4 56 John Deere 420-W Pix on Photobucket | | | | | Joined: Sep 2011 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2011 Posts: 54 | I'll try dawn on the outside rubber gasket. Thanks for the suggestions. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | If you have issues with the setting tape, I'd suggest taking glass & frame to a local auto glazing shop. They can install using polyeurethane glazing compound. Cost me around $ 50.00 | | |
