| | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | I have a bone stock 1953 Chevy 3600 with a granny geared 4 speed. I am curious is there a more modern 5 speed I could install in my tuck that would match up with the 216? And also what rearend would you guys suggest for a better ability to cruise the highway?
1953 Chevy 3600
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The T-5 from an S-10 pickup is the trans. of the day. Although it is not for heavy duty use it should stand up behind anything a 216 will do. The 4:55 rear end should work good with a .073 o-drive & tall tires. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | The T-5 from an S-10 pickup is the trans. of the day. Although it is not for heavy duty use it should stand up behind anything a 216 will do. The 4:55 rear end should work good with a .073 o-drive & tall tires. Thanks, any particular year S-10? I have 215/85/16 on it so hopefully I will get a little bit better ride.
1953 Chevy 3600
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | You'll want to look for the pre '92 S10 T-5s. Starting in 89/90 they went to electric speedometer. I just bought a 93 T5 and found out the hard way, it has a ford bolt pattern. As far as rearend goes, you could try to find the coveted 4.11 gears out of 68-72 GM 3/4 ton trucks with automatic. Or you could swap the rearend out all together. I have a 14 bolt 63" wide rearend waiting to go under my 54. Some guys have had good luck with the Dana 60's too. http://www.flatheadv8.org/ernie/ernie-t5.htm | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1982-86, some say 87 had speedo cable setup.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2012 Posts: 25 New Guy | | New Guy Joined: Oct 2012 Posts: 25 | Ok so I am on the hunt for a transmission from a 82-86 S-10.
And 4.11 rear end gears out of a 68-72 3/4 ton with an Automatic.
1953 Chevy 3600
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | This is NOT a bolt in swap so do a search on T5 conversions to see what all is involved. The T5 came with different shifter locations so if your keeping your bench seat you'll need one with a forward location. The T5 OD ratios ranged from around 0.82 to 0.67 IIRC so with 4.56 gears the Mustang 0.67 one would give a final drive of 3.05 in OD. Maybe too shallow for hills or bucking a head wind.
Evan
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The mid 80's T-5 from a S-10 is the best one. There is a tag on one of the bolts to the rear housing. It has a number in the lower left corner like 1353-xxx. Sometimes this number is on a sticker on top of the trans. 1352-145 is the best one. It has the most desire able ratios. When you find the number you can use a chart on a website called British v-8. to find the ratios & the original application. All the s-10 T-5s had the shifter in the foreward position so they will fit OK with bench seat. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
