5 members (GDW, Hotrod Lincoln, Gdads51, Jon G, ndkid275), 172 guests, and 1 robot.
Topics128,139
Posts1,056,455
Members48,441
#957221 07/18/2013 12:25 PM
Dear friends,
I have trouble with my 11" diameter clutch kit. Slide in 4th.
In my shop I have a complete 9" set new from another truck I had.
Is there any problem to exchange? I don´t use my truck to work, is just for daily drive
Alfonso
I put the 9" clutch in most of the jobs I work on. You are much less likely to have clutch chatter with the smaller disc.
My Blog
Riding in the Passing Lane
You can use the disc as long as the lining doesn't overlap the flywheel or pressure plate surface, but the pressure plate will not fit the flywheel. I ran my 6 cyl. with T-5 like that for a long time. I have since gone to a v-8 with 10 1/2 in disc.
1972 Chevy c10 Cheyenne Super
