0 members (),
146
Mod | | | Forums66 Topics128,162 Posts1,056,939 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | Looking for shock absorber suggestions for a 59 panel.
thanks
Is rust considered a body style?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | as original for all 3100 trucks: rear - Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060 front - Monroe 3100 [each] or Gabriel 82047 shock mount bolts - Monroe #AK 32
| | | | | Joined: Aug 2012 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2012 Posts: 45 | Thanks Red.
Is this what everyone is running or is there modern alternative?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | "modern"? like gas struts or air bags or coil-overs or something? shocks are shocks, those are the current production of the correct length and fittings for stock trucks, they do the job as designed
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you have stock suspension, you have leaf springs all around. They ride like a truck. Shocks control roll, pitch and yaw. Use any of those listed or $24.95 stock shocks from one of our sponsors. You don't need any more modern than that. According to Monroe, shocks control: Bounce Roll or sway Brake dive Acceleration squat
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
