7 members (EchoBravoSierra, MNSmith, TUTS 59, Goach2, LAROKE, Gray_Ghost, Lightholder's Dad), 87 guests, and 2 robots.
Topics128,173
Posts1,057,041
Members48,458
Looking for shock absorber suggestions for a 59 panel.
thanks
Is rust considered a body style?
as original for all 3100 trucks:
rear - Monroe "Limited Edition" LE10018 [pair] or Gabriel 82060
front - Monroe 3100 [each] or Gabriel 82047
shock mount bolts - Monroe #AK 32
Thanks Red.
Is this what everyone is running or is there modern alternative?
"modern"? like gas struts or air bags or coil-overs or something? shocks are shocks, those are the current production of the correct length and fittings for stock trucks, they do the job as designed
Sir Searchalot
Sir Searchalot
If you have stock suspension, you have leaf springs all around. They ride like a truck. Shocks control roll, pitch and yaw. Use any of those listed or $24.95 stock shocks from one of our sponsors. You don't need any more modern than that. According to Monroe, shocks control:
Bounce
Roll or sway
Brake dive
Acceleration squat
