4 members (JW51, rfs56trk, Cosmo, 1 invisible), 119 guests, and 3 robots.
Topics128,080
Posts1,055,956
Members48,430
#956224 07/13/2013 9:21 PM
Hoping you guys can give me some directions on how to test the fuel gauge and sending unit to see which one is not working on my truck. It is a 1970 C10. I replaced the fuel tank and the sending unit back in 2007 and the gauge has been working until recently but now it reads empty all the time. I removed the tank yesterday in order to do some work inside the cab and when I disconnected the wire to the sending unit the fuel gauge needle went way past full but when the wire was reconnected to the sending unit the fuel gauge needle went back to empty again. Don't know if any of that means anything but figured I would toss it in here anyway. Any info on testing procedures is greatly appreciated.
Ralph Davis
1970 Chevy C10 Webshots
My Stovebolt Gallery page
Old trucks never die, they just find a new home.
pull the sender and see if the float is full of fuel and permanently sunk or come off - it can be checked by using an ohmeter hooked between the terminal and the mount plate while running it up and down
