1 members (MikeE), 70 guests, and 2 robots.
Topics128,031
Posts1,055,436
Members48,422
I read somewhere (can't remember where) When changing a early 6 volt system to 12 volt, Its OK to leave the 6 volt starter in place. Saying the 6 volt starer will enjoy its new found power. True or False ?? headscratch
For with God nothing shall be impossible. (Luke 1:37)
http://s224.photobucket.com/user/72cj351/library/48-52?sort=2&page=1
Paul
true
providing you don't grind away with it for extended periods, like moving the vehicle wink
Thanks, I'll stay with the 6 volt starter.
Paul
True, do it all the time on the old 6v tractors. Starter will spin faster. Just don't grind on it for extended period of time.
The engine should start up faster anyway. On the old 2 cyl. Deeres, I just pull the start knob and quickly let off, engine is running.
57 GMC LCF 370
55 John Deere 40-W
59 John Deere 430-W
2000 GMC 4x4
56 John Deere 420-W
Pix on Photobucket
Besides the very impressive quick start up of the 6 volt starter on 12 volts, you don't have to change the ring gear on the flywheel to match the 12 volt starter gear.
Not if it's the same starter.
Ring gear swaps normally needed when replacing the 6v starter with a 12v starter.
If you just put 12v to the 6v starter you get the rapid start. Like Old GMC Gold I have done that to Jeeps, Tractors, Combines, Bailers, etc. for years.
Mikey
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
