1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Hi All,
I am trying to adjust my ignition timing on my 1955 235in engine using a timing light. My timing light has an adjustable knob on it. I know that not all the timing lights come with the adjustable knob. This is what I think I know, TDC on my fly wheel is the triangle mark but the bebee is the 5 degree advance at idle. The timing is done using the bebee. So, here are some questions. 1. If my gun is set to zero, I should set the timing so that the bebee is aligned with the pointer. Correct.
2. If I adjust my timing light knob to be at 5 degree, should I adjust the distributor so that the triangle is aligned with the pointer?
I am a bit confused with how to use the adjustment knob. When I have the timing light set to zero and I have the bebee aligned with the pointer, turning the adjustment knob seems to retard the strobe so the bebee is being retarded. I think that it actually should be moving the bebee in the advance directions? Can someone explain to me how I should time my engine using a timing light with the adjustment knob.
Thanks, skipper | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | First, the triangle is not for setting ignition timing. It is used for checking valve timing. There should be a UIC stamped near the BB. The line between the U and the C is TDC, or Upper Center. See picture. With today's fuels 235's like about 5 degrees more advance than the BB. I would set your dial on 10 degrees to start with and set the timing so the pointer is on the UC line and see how it runs. You can also set timing with a vacuum gauge.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Hey Pre '68 Dave -
Thanks for your explanation and pic of the timing marks, plus the meaning of "U C".
Also - you have a neat blog. I bookmarked it in the "reference" section of my links.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Nice picture of the mark Dave. The teeth on that flywheel make it obvious why it was removed.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2008 Posts: 261 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 261 | Thanks Pre68Dave for the explanation, it make sense now. I did not know about the UIC mark I will have to look for it. For some reason I thought the triangle was TDC but now I know it is for valve timing. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Since so many of these old engine/clutch-assemblies have been moved around, it should be noted that TDC/UC (valve timing mark) is in the same location on the flywheels for all engines. (please correct me, if this is incorrect - did some/all 261s have different valve timing marks compared to some same-year 235s)
However, the timing marks differed between 1937 and 1963 on 216/235/261 engines (for different BTDC or ATDC timing settings). The timing marks on your flywheel might not match your engine (to say nothing about original timing marks not being useful due to different octane modern gasoline)?
Those are a few of the reasons why adjusting/setting timing using the maximum-vacuum technique or the "ping" technique are usually better than using a timing light.
| | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | tclederman: I'm a little fuzzy on the whole "maximum-vacuum technique" for timing. would you mind explaining that? thanks.
1949 Chevy 4400 216
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Here's a couple links to help grasp the vac thing. I found the first one useful. Reading a Vacuum gauge vacuum timing
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 92 'Bolter | | 'Bolter Joined: Mar 2010 Posts: 92 | Thanks guys, that was really helpful!
1949 Chevy 4400 216
