| | | Forums66 Topics128,034 Posts1,055,533 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 7 New Guy | | New Guy Joined: Mar 2013 Posts: 7 | I have a 41 chevy AK 1/2 ton that has a 4 speed transmission that is un-syncronized so I have to "double clutch" it, I would like to find a tranny that I don't have to do that. so my question is, what years should i be looking for? thanks | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The only transmission that will be a direct bolt in is the 1937-46 truck 3 speed, with the 1940-46 being the best. 1937-39 has straight cut gears for first and reverse so they are a little noisier. The 37 trans would also need a 1938-39 front bearing retainer for the throwout bearing to ride on. (1937 was the last year for the carbon throwout bearing). The only adapting would be to add washers/spacers between the trans and master cylinder mount as the 3 speed is narrower where the mount attaches to the side of the trans. The 3 speed is not synchronized in first gear, only second and third.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2013 Posts: 29 New Guy | | New Guy Joined: Jul 2013 Posts: 29 | If you want the 4 speed a 48 to 64 is the best thing. It's an sm420 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think the transmission lengths for what Dave suggests are the same - no drive-shaft adaptation needed.
The SM420 is a different length (longer, I would guess).
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Tim is correct, much longer, along with the fact that the bolt pattern is different. Can you say can of worms.
