4 members (Bills54, Nick in Manitou, Bill Hanlon, Stovebolt48), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#949865 06/12/2013 1:58 PM
I have a 41 chevy AK 1/2 ton that has a 4 speed transmission that is un-syncronized so I have to "double clutch" it, I would like to find a tranny that I don't have to do that. so my question is, what years should i be looking for? thanks
The only transmission that will be a direct bolt in is the 1937-46 truck 3 speed, with the 1940-46 being the best. 1937-39 has straight cut gears for first and reverse so they are a little noisier. The 37 trans would also need a 1938-39 front bearing retainer for the throwout bearing to ride on. (1937 was the last year for the carbon throwout bearing).
The only adapting would be to add washers/spacers between the trans and master cylinder mount as the 3 speed is narrower where the mount attaches to the side of the trans.
The 3 speed is not synchronized in first gear, only second and third.
My Blog
Z
Z Offline
If you want the 4 speed a 48 to 64 is the best thing. It's an sm420
I think the transmission lengths for what Dave suggests are the same - no drive-shaft adaptation needed.
The SM420 is a different length (longer, I would guess).
Tim is correct, much longer, along with the fact that the bolt pattern is different. Can you say can of worms.
My Blog
