7 members (DadsFirstPickup, Otto Skorzeny, baldeagle, Youngin' Tut 59, 51sub, asilverblazer, Gray_Ghost),
49
Mod | | | Forums66 Topics128,180 Posts1,057,146 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 12 New Guy | | New Guy Joined: May 2013 Posts: 12 | Mines been converted to 12 v already. I have the back wheels of he ground to try to free the drive train. I can spin the drivers side but the pass won't move. Spinning drivers side doesn't seem to move the drive shaft. Is it likely in gear or locked up brake or bad rear end? If drive shaft won't spin should I still be able to turn the motor by hand? The motor looks ready to try to start but figured I ask first. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Clutch disc stuck to the flywheel? | | |
