5 members (klhansen, 5 Window 9434, farmallb, Peggy M, 1 invisible), 59 guests, and 3 robots.
Topics128,024
Posts1,055,393
Members48,422
#953876 07/01/2013 8:18 PM
My 49 half ton has a 235 from a '56 but dunno if from a car or truck. Is there a way to find out if it's solid lifter or hydraulic lifters... It's pretty quiet to be solid..
Mark
1949 Chevy 1/2-Ton
Lucielle
Name after my Uncle's Wife..
More pictures on Photobucket
If there are no dogs in heaven, then when I die I want to go where they went. ... Will Rogers
What's the serial number stamped on the pad next to the distributor?
Bill Burmeister
I'll have to get back to you...but thanks for the reply..
Mark
1949 Chevy 1/2-Ton
Lucielle
Bill;
I've wondered the same thing. Can you provide a quick history on solid vs. hydraulic lifters? Which came first? When did they switch? Is one better than the other???
Larry
Larry,
This is what I read that started me thinking and wondering...
http://chev235guy.blogspot.com
Mark
1949 Chevy 1/2-Ton
Lucielle
At the bottom of this page is a rundown of mechanical and hydraulic lifters in 216/235/261 stovebolt engines.
Pre '68 Dave's blog on this topic.
All stovebolt truck engines used mechanical lifters. Mechanical lifers were a little more noisy than hydraulic lifters. Hydraulic lifters do not work well at sustained high RPMs, but were quieter for normal family driving.
Some people would say that hydraulic lifters are easier to adjust, and some people also say that hydraulic lifters stay properly-adjusted longer.
advantages and disadvantages of hydraulic vs mechanical lifters
solid/mechanical vs hydraulic
interesting discussion of hydraulic lifters in a valve-in-head engine (our stovebolt engines are overhead-valve engines - easier to adjust the mechanical valve lash)
tappets not the Tappet Brothers
I read that blog....that's what got me started asking questions... I dunno if my 235 came out of a truck or car though.. I'll have to look at that number beside the distributor... It's in the shop now getting pipes done..
Mark
1949 Chevy 1/2-Ton
Lucielle
