0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | I'm rebuilding a 3/4 ton GMC truck and the front pinion shaft seal on the rear end was leaking.
So here are the part #s for the new seals and parts.
Frist you will have to have a 1 5/8 thin wall socket,I got mine at auto zone for 11.00.
After removing the yoke off the front my yoke had a deep grove where the seal was so I ordered part # 99259 National repair sleeve.After installing you will have to remove the installing flange,read directions !
After that you'll have to remove the 5 bolts holding the front cup thats on the rear end that is where the seals are.
Both seals are National #s
Than you'll need two seals # 5M89 that will be the felt dust seal.
Than you'll need #411330N that will be the rubber seal.
I made my own gasket out of some very thin gasket paper to fit between the front seal cup and the rear end.
Take You're time and enjoy the build,Pete
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks for posting those numbers Pete, saves us the leg work of chasing them down our selves. Wish Charlie would chime in as to the differences in the Chevrolet and GMC rear ends. Still not sure that the 3/4 ton GMC's used the Eaton HO52 like Chevy did. Denny Graham Sandwich, IL
Denny G Sandwich, IL
