1 members (Bill Hanlon), 48 guests, and 5 robots.
Topics128,012
Posts1,055,318
Members48,419
#953075 06/27/2013 5:45 PM
I have a 51 Chevrolet suburan and need the rear panels to match the brown cardboard door panels I have any help out there thanks
if you have a long established auto upholstery shop in your area they should be able to order in that type of material
Jim Carter has them. I'm curious to know what people are using for the thin metal trim which covers the cardboard edges.
Sir Searchalot
Sir Searchalot
BTW are these door panels and rear panels actually cardboard or something a little better? coated? painted?
The cardboard panels are painted on one side and are not very well sealed on the edges and the back. I have to replace the panels on my Suburban (minimal moisture has ruined a few panels). I will seal the backs and sides/edges on the new panels with epoxy primer.
Sir Searchalot
Sir Searchalot
So they are cardboard like cardboard box cardboard? Like I could make myself and paint? Or some better stuff? Reason I ask is I could use for other places and vehicles.
the upholstery type 'cardboard' is about 3x the thickness of the usual boxboard, but less than corrugated - here's a currently available type, better quality than the 50's era stuff, and than the repro panels in my experience
Sir Searchalot
Sir Searchalot
Wow! great website, looks like all good stuff. thanks Bill. So you have ordered from them?
in the past I've gotten similar stuff via a local auto upholstery shop, an older established shop will be familiar with the stuff, comes in fairly big sheets, probably enough to do a panel/burb rear headliner
