2 members (VicZ, klhansen), 118 guests, and 3 robots.
Topics128,072
Posts1,055,904
Members48,429
#95336 04/11/2006 10:37 PM
8
8 Offline
Just looking at my speedometer there can't be that many parts to it. Has anyone rebuilt theirs?
What about the other guages? My Alt. guage doesn't work either. Can someone recommend a honest rebuild service? Thanks, Bert
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
Ex Hall Monitor
Ex Hall Monitor
From past experience I would STRONGLY recommend going to your local library, looking in all of the area telephone books for a speedometer shop in your area. I took the well intended recommendation from someone here to use Scott Speedometer. He was very expensive and had to do it twice. It still isn't right but usable. There was a two week turnaround each time I sent it to him plus extra shipping cost. After I got into this deal I discovered a shop 50 miles away that could have done the job. Many speedo shops also repair the other gages too. Good luck.
I took mine all apart, cleaned it up, reset the odometer and put it all back together. All seems to work. I guess that would be a "qualified OK" as I have only been around the block 7 times (3.5 total miles) and a maximum of 5 mph. The trick is holding all of them little number wheels and the small gears in between all together while inserting the shaft and little stop rings. One needs 3 very tiny hands and nimble fingers, but it can be done. The finish on the odometer numbers is very thin so be careful when cleaning them
1941 Chevy Master 3/4-Ton
More images in the Bolt Bucket
Born to fish, the truck is only a hobby.
I've used Albuquerque Speedometer (New Mexico), the guy has been in the business since the 60s and is fantastic and reasonably priced. I posted his number in another thread or you can get it from dexonline.com
Junior Member
Junior Member
Shouldn't you try replacing the speedometer cable to see if that fixes it, that's all it took for me to get mine going ok.
As for the Alt. gauge, you dont need an altimeter reading in your truck anyway, I would advise against getting any 'air' in the truck they arent made for landings. ;-)
