| | | Forums66 Topics128,014 Posts1,055,325 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 16 New Guy | | New Guy Joined: Nov 2012 Posts: 16 | I have a 51 Chevrolet suburan and need the rear panels to match the brown cardboard door panels I have any help out there thanks
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if you have a long established auto upholstery shop in your area they should be able to order in that type of material
Bill | | | | | Joined: Jun 2008 Posts: 48 'Bolter | | 'Bolter Joined: Jun 2008 Posts: 48 | Jim Carter has them. I'm curious to know what people are using for the thin metal trim which covers the cardboard edges. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | BTW are these door panels and rear panels actually cardboard or something a little better? coated? painted?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The cardboard panels are painted on one side and are not very well sealed on the edges and the back. I have to replace the panels on my Suburban (minimal moisture has ruined a few panels). I will seal the backs and sides/edges on the new panels with epoxy primer.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | So they are cardboard like cardboard box cardboard? Like I could make myself and paint? Or some better stuff? Reason I ask is I could use for other places and vehicles.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the upholstery type 'cardboard' is about 3x the thickness of the usual boxboard, but less than corrugated - here's a currently available type, better quality than the 50's era stuff, and than the repro panels in my experience Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Wow! great website, looks like all good stuff. thanks Bill. So you have ordered from them?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | in the past I've gotten similar stuff via a local auto upholstery shop, an older established shop will be familiar with the stuff, comes in fairly big sheets, probably enough to do a panel/burb rear headliner
Bill | | |
