3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#95268 04/02/2006 4:03 PM
What are the components necessary to convert a 52 Chevy PU from 6 volt to 12 volt?
#95269 04/02/2006 4:52 PM
Riding in the Passing Lane
12 volt bat., gen-reg or alt-reg.,all light bulbs. Coil & resister. Starter switch with bypass. Resister for gas gauge (see posts nearby).12volt heater motor or resister,. Radio.Turn signal flasher. If i,ve left anything out fellow bolters help out.
1972 Chevy c10 Cheyenne Super
#95270 04/02/2006 6:38 PM
spyder68,
Just in case you have not yet checked out the Tech Section of this site (see Tech Tips at the top of this apge), here is the 12 volt conversion Tech Tip.
The EL110 resistor that is listed at the bottom of that page might not be a Runtz resistor , which is recommended by many (but not all) people.
Tim
#95271 04/03/2006 4:30 PM
You might want to get a copy of The Offical 12-Volt Conversion Guide from Fifth Avenue or Speedway Motors. The book is a step by step guide and explains everything you need to do to get it righ the first time.....Randy
